ShootToThrill
Been smelling gear oil after running 80+mph on rr grades for a few miles at a time. I can smell it on the normal slower trails too sometimes. Can touch the case for a second but thats it, its as hot as the oil tank. Since the first ride I noticed it, I had the upper bearings replaced and a complete gear/chain swapped out. Yes oil level is good and ran OEM oil, tried different tension on the chain, and all parts look good. Tried Klotz oil and no help there either. I see no obvious problems inside, what gives?? If somebody could run on a rr grade then check the temp, let me know what a normal case runs at that would be some good info. Less than 5000 miles on my sled. Heck it smells like gear oil maybe it's something else??
