garyr
- Nov 7, 2011
- Paradise, Nl..Canada
- 2010 Nytro XTX
as u can guess I am not mechanically inclined and I want to change my oil...how do u get the factory belly pan off the nytro...any help would be appreciated...thanks
kurtasaurus80
Unfortunately; you're going to have to pull a lot of plastic off. Start with side panels, then left & right lower side panels; there is one 10mm bolt at the bottom and 4 (i think) push retainers holding the lower panels on. Once those those lower panels are off, the 4 push retainers of the belly pan; should be accessible.
When changing oil, remember to remove that little bolt at front of engine to drain another 250ml.
nytrorider28
- Nov 14, 2010
- Marion, IA
- 2014 Yamaha SR Viper LTX
2007 Skidoo MXZ 600 SDI
Past:2009 Yamaha Nytro
If you have your manual there is a great step by step section. Any tips just take your time and give your self a few hours. It does take some time. Good luck.
garyr
- Nov 7, 2011
- 2010 Nytro XTX
I have it done guys thanks for your help..not near as hard as I thought...this site is great for getting help...thanks again
garyr
- Nov 7, 2011
- 2010 Nytro XTX
Just wondering the manual calls for 3.2 litres with a filter change which I have done, but I am just showing down at the low or bottom of the marker on the dipstick...is this normal...I have put 3.2 litres in the machine
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
garyr said:Just wondering the manual calls for 3.2 litres with a filter change which I have done, but I am just showing down at the low or bottom of the marker on the dipstick...is this normal...I have put 3.2 litres in the machine
Normal I don't know but it was the same for me. I started there then added till it was full on the dipstick or just a bit under full.
garyr
- Nov 7, 2011
- 2010 Nytro XTX
Yeah I was thinking about doing that but I am afraid I will overfill it and that is just as bad as having low oil..would appreciate hearing from others who have seen this and what they did about it....thanks
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
garyr said:Yeah I was thinking about doing that but I am afraid I will overfill it and that is just as bad as having low oil..would appreciate hearing from others who have seen this and what they did about it....thanks
If u overfill it just drain a bit out, no big deal. Actually had to do that too. Now shes right on the money
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Due to these units being a "dry sump" type, over filling is not as bad as you think. The pump only pulls enough to fill the gallery and and lower end. It's not like a wet sump where it could over pressure your system and blow out seals. But of course it's better to run it at the nominal level for expansion etc..garyr said:Yeah I was thinking about doing that but I am afraid I will overfill it and that is just as bad as having low oil..would appreciate hearing from others who have seen this and what they did about it....thanks
