Cable810
- Jan 25, 2018
- Rogers City
- 2015 Viper MTX MPI 190
- Rogers City Mi
It's the cover for the bearing behind the secondary clutch. I searched on here and have come up empty handed. I've been prying on it and it only moves maybe 1/16
https://photos.app.goo.gl/8bSePBYoRUDs292w9
SaskAttack
- Jan 4, 2006
- Corning,SK.
- 17 Sidewinder XTX-SE
- Corning, SK. Canada
Do you mean the bearing seal?
Cable810
- Jan 25, 2018
- Rogers City
- Rogers City Mi
Is that what that is? Can you see the picture. I want to repack that bearing.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
I usually pull the chain case cover but this video shows how to remove the jackshaft with the bearing. If you repack the bearing then just pop off the seal with a small screwdriver or pick.
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
I always repacked that one by removing the snap ring and pulling the seal. no need to pull it unless changing it
Cable810
- Jan 25, 2018
- Rogers City
- Rogers City Mi
So that metal piece I was trying to get off doesn't come off unless the whole shaft is removed.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
The bearing is pressed into carrier and also on the shaft so it's easier to deal with with the jackshaft out.
seal comes out with a pick. I start gently on the seal next to the inside race of bearing.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Should pick it from the outside. The inside is the sealing lip that the bearing rotates on and you don't want to damage that.
I use a brass pick or a toothpick. Never had any trouble and never distorted a seal. Much easier from the inner.Should pick it from the outside. The inside is the sealing lip that the bearing rotates on and you don't want to damage that.
Cable810
- Jan 25, 2018
- Rogers City
- Rogers City Mi
Thanks for the help guys! I also came across this for future reference
https://ty4stroke.com/threads/jackshaft-and-driveshaft-bearing-re-grease.113610/
Cable810
- Jan 25, 2018
- Rogers City
- Rogers City Mi
I feel like an idiot putting the stuff for the secondary back together and stupid me forgot how it goes back together.... Is it little snap ring, washers then big snap ring or is it washers little snap ring then big snap ring?
I know the big snap ring is to hold the seal in place. The little snap ring won't get into the Grove on the shaft of the 3 whashers are behind it. I'm looking at the diagram and it doesn't make sense.
It feels like the seal is all the way in cause I cant push it in anymore and I only have room to get the little snap ring in place.
Doesn't help none that I'm a little buzzed up
