wizard243
I know I read this somewhere, but can't find it.
I have the heavier spring to put on.
Seems like someone said the spring can replaced without taking out the skid.
Any help would be appreciated.
welterracer
Loosen the rear axle nut
Loosen the track..
unplug the shock wire.. (remove any necessary zip ties)
Unbolt the shock
push shock back and upwards and let the front part drop down and out..
Its VERY EASY... but be very carefull with the shock..
Loosen the track..
Unbolt the shock
NY_SXR700
- Dec 30, 2003
- Webster, NY
- www.sohonetworksny.com
- 2001 SXR700
2006 Apex-GT
Spray the track above your rear shock mount with a little WD-40 or your favorite lube. Then the shock end will slide against the track much better. Welter left out that you need/should remove the rear bolt on the transfer rod also. This will drop the top bracket and let you slide the shock arm back. Do a search on the wire for the shock and follow it. Someone posted the page for the correct zippy tie position. The electric connector is the same as you will find under the hood, it has a little tab you push to release it. Doug
welterracer
Ive had my shock out TWICE.. and never removed the bolt from the transfer rod..
RX4RACING
What he said!!
NY_SXR700
- Dec 30, 2003
- Webster, NY
- 2001 SXR700
2006 Apex-GT
Wow SORRY not inteneded to offend. I had a hell of a time getting mine out/in with the bolt out or in. I found it to be much easyer with the bolt out. Also the lube on the track is a must if you don't want to sit around and wiggle wiggle wiggle until it's in place.
welterracer
no offense taken.. just bustin your chops.. LOL
Good idea on the lube.. i did that too..
SledFreak
- Feb 7, 2005
- Ontario. Canada
Where do you un-plug the wire?
YammiMoose
- Mar 18, 2004
- In a place where it SNOWS every day
SledFreak said:Where do you un-plug the wire?
Inside the plastic boot that is Zip Tied to the shock.
you can also follow the wire up into the sled & unhook. Pay attantion to what you remove and where. Then you do not have to worry about getting the zip ties back in right place. I have had mine out twice with no issues. Just pay attention.
Doug
Doug
YammiMoose
- Mar 18, 2004
bjniceguy said:you can also follow the wire up into the sled & unhook. Pay attantion to what you remove and where. Then you do not have to worry about getting the zip ties back in right place. I have had mine out twice with no issues. Just pay attention.
Doug
here is a picture showing the wire route.
-Moose
