4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
I'm posting here because it'll get more looks plus I think the question could pertain to other models. But please move it to the RS forum if required.
Sled = 2005 Vector ER
The attached pictures show what I call the main link between the steering arm that goes down the RS of the sled and the center steering linkages in the front center of the sled.
Both heim joints have tapered ends and my guess is that the old ones may very well be difficult to take off. I'm guessing a dealer has a special tool or a special trick to do this. Maybe someone out there can help me with some tips.
I'm very hesitant to tackle this myself as if I screw something up, it'll have to go to a repair shop and the rest of my season is likely done. Yes, I can wait until summer.
TIA for any help you can give.
- Mar 25, 2010
- Nova Scotia
- 2016 APEX LE XTX
What's wrong with them, what problem are they causing.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
After 20K+ miles, there's slop in both joints, especially the one in the center of the sled. I'm working on tightening up the steering and this is just one place I'm working on.
Have you tried asking a service tech how they would remove them? I will sometimes go to a dealership and ask to talk to a tech about stuff like this, and generally they have no issue with letting me walk into their shop and ask their tech some questions. Most of the time I walk away with some useful info, or at the very least some insight as to how things are meant to come apart and what to try if things don't go as planned.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
A small 2 jaw gear puller? Maybe a wiper arm removal tool like this would work?
Or just whack the stud with a hammer
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
I was at my local Yami dealer today and the wrench said to hit it with a hammer. Nothing will break....he assured me. There's a first time for everything and it usually happens to me.
stohlem
- Jan 11, 2015
- 2017 Sidewinder LTX LE, 2014 Apex XTX
- Illinois
sounds like a tie rod end on any heavy truck or car. typically if i do not have the right size pickle fork, i smack beside where it goes through the spindle with the apropriate sized hammer for the vehicle. if you have new nuts for the new tie rod ends, you can thread them on so that the tip of the stud is flush with the nut and beat on the nut to remove it. for areas that you cannot get at the nut, you can use a wedge like above or just hit the side next to the knuckle with a chisel. do this all the time at work on heavy truck with a 16lb sledge.
You just hit it with a hammer. The female portion it fits into that is.
Snorunner
- Jul 17, 2018
- Deerwood
- 2016 Vector XTX
2017 Vector XTX
2001 Arctic Cat
I agree with the dealership technician. If you can hit the part the tie rod or steering linkage helm joint connects to with a hammer. The vibration should work. I have disconnected thousands of tie rod ends and ball joints. Automotive ones mind you. I have also used Pickle Forks. When I did not need to care about the grease boot.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Thanks for all the help!! I'm wondering why I'm not getting email notifications for all these replies though! Will check my setting.
The "hit it with a hammer" trick worked. 2 or 3 hits on each and they popped out. I was nervous hitting it so hard but it worked! On to the next project (cleaning carbs) as I've got no one to ride with.
Roger
- Feb 10, 2007
- Osgoode Ontario Canada
- 2012 RS Venture GT (power steering doesn't work when real cold)
2006 Indy 500
I wouldn't use the hammer on the carbs though
