Codes are 13 and 25. I don't know if they are fixed. I installed a supercharge kit and the gems computer that came with the kit had two wire switched. I pretty sure this caused the codes to appear because I plug the gem into my stock sled and the code come up. When I removed the gem and hook the factory back up the codes didn't go away. I called MPI and they said the switched wire would cause any damage and that I would need to reset the comupter to fix the probably. They didn't know how to reset the computer, suggested to disconnect the battery, and that they would get back to me when they find out if there is a differnet way to reset the computer. Could be similar to how car are reset.
Thanks for the reply. Any suggestions.
