how long does a botle of nitrous last
bottlefed
how long will a bottle of nitrous last when shooting a 60 shot through a boss noss system. I think that it comes with a 2.5 pound bottle and I was woundering how often I will need to refill it.
about 10-12 5 second runs in stock boss trim. i changed the solenoid and now i am using twice the ammount of nitrous. you might get maybe 7 shots with a bigger solenoid.
is that running a 2.5 bottle and also how much difference does the bigger solenoid make
I don't believe you get a true 60 horses with Boss. I have a NX and N.O.S. kit on 2 Apex's and I get 3 to 4 10 sec hits with a 40hp shot with a 2.5lb bottle filled to the brim. YEEEE HAAAAAA. I've seen dyno sheets posted on here that show rated HP but dyno and real world HP are 2 different things.
Seven 5 or three 10 sec hits seems about right with true 60 HP and 2.5 lb bottle. ;)!
I carry an extra bottle in a backpack because it goes quick and I refill the bottles after every ride. :Rockon:
yep its with a 2.5lb bottle. with the stock solenoid the rpms just creep up to 11,200, with a nos solenoid installed the needle pegs to 11,200 as soon as you hit the bottle, its a night and day difference!!!!! it hits so much harder.
HUH?
What do you mean?
How else can I explain it?
Dynos show #'s within a closed controlled environment. #'s in the real world vary based on condition's; ambient temp, bottlepressure, fuel pressure, snow conditions, track and suspension setup etc.
Sorry 10-12 5 sec hits of nitrous do not add up to 60hp with a 2.5 lb bottle.
check out page 5
http://www.holley.com/data/Products/Tec ... 8-SNOS.pdf
60hp is = too
2.5 lbs N2O/.72lbs in 10sec.=3.47 10 sec hits of juice
NItros
And how much to fill a 2.5lb bottle?
Trying to figure what it is going to cost for a few giggles.
Bruce
A budy and I had to resort to buying a nitrous pump off of e-bay for $700 and we buy the nos in 65lb bottles for $400. About $6 a pound.
We did this because buying nos in northern Alta. is a bit unreliable. When you want nos YOU WANT NOS.
javascript:emoticon(':nos')
NOSjavascript:emoticon(':jump:')
Jump for Joy
Re: NItros
Bruce
Where I live I can get it for 3.95 lb
check out page 5
60hp is = too
Hey, that Holly info is pretty good. I have the 50HP set up with a 3lb bottle. That seems pretty close to what mine lasts. I get 50-60 seconds total...depending on bottle pressure. That math works.
