yamiboost
- Feb 17, 2008
- Labrador,
- 15 SR Viper MTX Hurricane 300hp kit
Fx Nytro Drag Sled 25psi + Boss Nos
I want to give the attak a little more track, thinking 151'' would this be too long for extencions? would i be better off going with new rails? also where is a good place to get the tunnel extension and rail extension/rails? Not looking to spend a bunch as the most this sled does is collect dust. I like my mtx so much better im thinking the attak now has to go longer
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
I like the parts from http://hartmaninc.com/ he makes good strong parts. I think going to 151". Should be fine maybe add some support for the rails. But you also could move the skid back 4" and make it a 144" with a great attack angle.
DAGE
- Nov 8, 2005
- where the snows at
- Other
- 06 Attak
it depends what you want to do, I drove my RX1 mtn on the trail and trying to keep up to short tracks was a challenge, I'm stretching my Attak to a 144" however I want to get tipped rails to help with trail riding, if you mostly drive in the deep stuff then go with the 151", you'll love it
yamiboost
- Feb 17, 2008
- Labrador,
the trails are ungroomed here most of the time and 80% of the riding i do im making my own path so a short track is useless for me. I love my 162'' apex for the way i ride but i was more wondering about strenth of the rails with that long of a extension compared to going 151'' rails i have never extended a sled before.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
If you add rail supports they will last.
sherlock29
I have hartman's kit comming... 151" tunnel extention with a 144 track length.... the tunnel extention is 20 3/4" long, 144" is 15 3/4" long and stock apex is 9 3/4" long... I have a 144 track already, but wanted a wee bit more room for fuel caddy/rack on back... I'm in the middle of these mods now, just waiting for kit to arive. this is all going on my 40th... but i still have work to do to my rails... i have some tweaks in them i don't like and found some small cracks that are going to get welded up.
yamiboost
- Feb 17, 2008
- Labrador,
Thats awesome sherlock29 you should add a pic of that extension when you get it installed. I too would like more room to carry fuel sounds like hartman is the way to go.
thanks
thanks
sherlock29
I talked to Tom Hartman for sometime, and i didn't want one of his off the shelf kits, so i peiced one together.... for my wants and needs... yes i will be posting pics and everyhting once i get going... my sled is currently apart.... very apart... took my front rad out on the weekend(stud thru it) so once i drilled the 26 rivets to get it out, fighting and cursing its time to get things back together.... I'll probably start a thread of my build...
