How many HP with this setup????
lsp_racing said:
KN filter intake PC3 and slip On????
Which slip on? K&N's should be good for 5-6hp mid-range and 2-3hp on top. The PC3 doesn't really add hp but helps you dial in the mods to perform at peak level (i.e. - more fuel on top needed w/filters).
Depending on which slip on you go with most are good for 2-5hp above stock. My experience is that hp is for top end results.
Does this help? ;)!
Does this help? ;)!
and some good weight savings :Rockon:
arteeex said:
I'd say you can expect about 1-million horsepower, give or take a little bit.
