YAMAHAMMER101
I was just wondering on how much sea foam you guys are using. I added 8 ounces to a tank of gas ..does that sound about right? I am not burning any oil I was just doing it for general maintenance. For carb cleaning and slight decarbon.
Thanks in adavnce
Thanks in adavnce
Red2003
Should be fine. I believe the can calls for one ounce per gallon, so that should be pretty close.
8-10 ounces to a tank of gas should do the trick!!
YAMAHAMMER101
hey guys thanks alot. i figured an ounce per gallon would do it but the back of the can just says it treats between 35 to 90 litres.
- 7K
