cw xtx 1.75
- Jun 12, 2014
- 2013 Yamaha Nytro xtx 1.75
I am looking at replacement bulbs for my 2013 nytro . I am thinking phillips crystal vision xenon . The package says 67 60w is this to much load on the stator ?
patamaran
- Aug 9, 2015
- Westree Ontario
- 2008 Fx Nytro
60w at 12 v is 5 amps what is your headlight fuse rated for? Diagram says 20 A. If that's all true then you are well within the rated amperage of the fuse, wires, and system design since usually your fuse is sized to protect the mag. I'm an electrician, this is my opinion but automotive protection standards may be a different story. What is your stock bulb rated for? I would try to stick as close as possible to the stock wattage.
Sent from my SM-G900F using Tapatalk
