- Mar 1, 2004
Preacher said:Thanks Tom , just another obvious reason why this is such a great site
ABSOLUTELY.....Great info Boss
- Mar 1, 2004
MrSled said:Hi guys... yes it will get out of adjustment. Mine was out after 2500 miles, I noticed fuel mileage and top end loss.
I would think you would want to adjust or check after every season or at least check after the first season.
Is this due to just cable stretch or vibration?
Once a season adjustment or possibly more?
Mine was out of spec as well. Only have 2550km on it, so roughly 1200 miles and it took about 6 tries to get aligned. Video was a great help!
whits-end
- Mar 2, 2004
STAIN said:Do you believe that once you confirm the position of the EXUP valve the first time you can use just the diag screem to adjust your cables there after? If you need to see 0 and 180 on the diag screen I assume this is all you need to adjust the cable free play(?)
Not sure I understand. I just followed the video (which was a great help), cycling via the grip adjuster then key on to check the notch. Is there more to it than that?
BTW, at about 3800 kms or 2400 miles mine was still within the notch but ever so slightly to the right. How critical is it to be dead nuts in the centre?
Thanks again for the video.
kered
- Mar 22, 2014
- Newmarket, Ontario
- 09 Apex GT
Do the 09 Apexs have this EX-UP valve?
no 09 does not. only 2011 up did.
Well, just got done the 16 and it took me an hour to get it set. 2700km
and i forgot to mention, i replaced the xup cables on the 2011 last season and this year it was still in spec and it had 3500km at least since i installed them.
Does the 2015 Vectors & up have the same set-up.
no the vectors do not have the exup valve in the exhaust.
Thank you for the response.
Mileage Quest
- Apr 12, 2013
- MPLS, MinneSNOWda
- '12 Apex X-TX
Sweet !!! Mine wasn’t broken until I entered Diagnostic Mode ,,|,,
how is did everyone set theirs to full open???
