How do i disconnect the high beam? I would want to only use low beam, and head light off when switched to high beam. Or install a switch before the high/low switch....
Nytro XTX 2011.
Nytro XTX 2011.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
there are three wire going into the the back of each headlight. I believe the high beam is a yellow wire. You can cut both yellow wires near the bulb connector or cut it at the headlight relay.
