GregoryN
- Feb 23, 2019
- Ottawa
- Yamaha SRX 120
Hi we just purchased a 2018 Yamaha srx 120 for our son. He is 3.5yrs old and we find for his first time out around the yard we would like the 120 to be a bit slower. When the clutch engages no matter where i put the speed control screw adjustment the sled still goes to fast for my liking. I adjusted the speed control screw down it helps with slower take off but when the snowmobile clutch fully engages the snowmobile still goes to fast. Any clutch adjustments or anything. Is there such thing as a lower gear? Thanks any help would be appreciated.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Maybe a Shim or wedge taped behind the throttle lever?
you could try gearing it down some but not aware of the gear ratios availible for it. i do know it uses #40 chain on it.
Surestick
- Jan 19, 2015
- '07 Phazer Mountain Lite
I was going to suggest this too.
kirkswim
- Jan 11, 2009
- sudbury ontario
- Yamaha RXWarrior
When my buddy's son started driving his Polaris 120 he tapped a dead 9v battery behind the throttle lever. His son was 4.5 years old and he found that even with the speed control screw turned all the way down his son would go way to fast especially on left turns(he would push the throttle and the bars at the same time). As he got older he changed to AA then no battery and started turning the speed screw up.
