How to make the Nytro more tippy side to side
Bottle of whisky and five feet of powder! My bad......
pump front shocks up hard , rear springs on Hard , if u have rear clickers same thing ,basically crank everything up . be a stiff ride but will be more tippy if thats what your looking for . (also cheapest and easiest) ) can always reverse what you have done if you don`t like it with no money invested :) . I guess taking the bolts out of the sway bar would also help and no cost
So do i want me limiter straps longer or shorther? Im assuming if they are longer your center of gravity will be a little higher. Also on my fox float x do i want to run a higher or lower psi. IM running 65 right now. My front skid shock is set very basically no preload. do I want to change this?
