blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
How many are not using the stud and nut on that middle hard to get a bolt in or out on the exhaust flange? Is a bolt even needed there?
idontknowjack
I use it.
NYTurbo
If u don’t use it , it will leak there
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Hmmm....I have a TD sq and there is no hole in the flange to put a bolt in.If u don’t use it , it will leak there
justinator
The td mufflers dont include the area for the bolt and no leaks. The precision, viney fab and stock exhaust do not leak if you do not use the "difficult"bolt. I never have on any of the mentioned mufflers and zero leaks. The hurricane muffler will leak without using all mounting holes. That has been my experience anyway.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Ok thanks guys I’ll keep using it
NYTurbo
Has a lot to do with thickness of flange and how flat they are on the muffler
Turboflash
- Mar 18, 2019
- Southern MN
I always have bolt there. I changed T50 torx to M8 x 1.25 bolt there. Then, I slot the flange on muffler so I can leave the bolt in which also allows steel gasket to hang on that bolt when muffler is off.
I've seen many sleds with those bolts over-torqued (which can, and does sometimes bend muffler flange so it's no longer flat). Manual says tighten to 9 ft.lbs in criss-cross pattern, then final torque to 18 ft. lbs.
stgdz
- Mar 27, 2021
- Buffalo MN
Pulling these trail performance muffler is a pain in the neck.
2004yamahaviper
- Sep 11, 2010
- Ottawa, Ontario
- Spring order 2021 srx
2012 Apex xtx
Had the hurricane muffler on for a few years now. Used the bolt the first time and that was it. No issues
