jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Sucks.. Sometimes its a sh*& show.. Hang in and again its not snowing YET
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Did the same thing. I broke the bolt and someone tried helping me broke off the extractor inside as well. Will there be any issue running it like this until we can figure out another solution? Might try welding a bolt method to it. Any other ideas welcome thanks guys.Update. haha turbo is off, headed to a shop to get it out. broke extractor inside the hole. Went though 5 drill bits just trying to get through the bolt. Its a great time over here.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Should be fine without it. You’ll see if it leaks, will be dirty around that spotDid the same thing. I broke the bolt and someone tried helping me broke off the extractor inside as well. Will there be any issue running it like this until we can figure out another solution? Might try welding a bolt method to it. Any other ideas welcome thanks guys.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I've been running with one missing for 5 years. No worries. Like Big Phil said you'll know if it's leaking.Did the same thing. I broke the bolt and someone tried helping me broke off the extractor inside as well. Will there be any issue running it like this until we can figure out another solution? Might try welding a bolt method to it. Any other ideas welcome thanks guys.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
If it leaks is there anything I can do? It’s the top right looking at turbo. I put copper sieze on the bolts. Now have all stainless in as well. The one that broke came with the precision exhaust, torqued to 9 lbs then 18lbs with copper sieze. I do have nickel Anti coming which I’ll take the bolts back out and put that on the bolts also. Thanks for the help guys
Big_Phil
- Feb 5, 2014
- Sidewinder RTX LE
Stock exhaust bolts are the best. No anti seize or anything necessary and they don’t break or stretch. That being said, you shouldn’t leak with 1 bolt missing. Most, if not all, the after market exhausts don’t use all the bolts.If it leaks is there anything I can do? It’s the top right looking at turbo. I put copper sieze on the bolts. Now have all stainless in as well. The one that broke came with the precision exhaust, torqued to 9 lbs then 18lbs with copper sieze. I do have nickel Anti coming which I’ll take the bolts back out and put that on the bolts also. Thanks for the help guys
zxtyler
- Dec 12, 2020
- Michigan
- 2020 SRX
I’ve been using td sq 3” and theres not even a tab for a bolt in one spot. Hasn’t leaked in 2500 mi.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Ok thanks guys. So should I put stock bolts back in or try the stainless steel
Kuzzy
- Dec 6, 2020
- saskatchewan
- 2020 yamaha sidewinder xtx se
2022 STX GT
2017 King Cat M9000
I would stick to stock bolts, use the anti seize recommended, lots of people with good luck using it
to get a broken easyout out, sharpen a cement carbide bit to drill steel and you can drill out the bolt/easy out. it is slow going but can be done. just had to do this to lower shaft bolt that broke in the chaincase on brothers 09 apex mtx.
