twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I am not sure what they are using but they should probably be printing them out of something like PA6-GF filament (Nylon 6 w/glass fiber). It has a max temp range of at least 375° F.Crap Gotta dig into mine and recheck after my last trip. Wonder if there is a more heat resistant material he could print them out of?
Turboflash
- Mar 18, 2019
- Southern MN
Probably won't though due to cost. I think current material they're using is just cheap ABS at $2/kg.
PA6-GF costs $50-60/kg.
Turboflash
- Mar 18, 2019
- Southern MN
Can't get Dave to call me back so IDK. Disappointing.What does Hurricane say about this???
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I might be ABS but they would need an enclosed 3D printer then. ABS off gasses when printing and needs a vented enclosure. Might even be the cheaper PLA or PETG.Probably won't though due to cost. I think current material they're using is just cheap ABS at $2/kg.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
These sleds your finding these on do they have any additional venting up front? I have two vents up front in addition to knee vents which may help keep temps down.Probably won't though due to cost. I think current material they're using is just cheap ABS at $2/kg.
0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
These should be made with better material obviously. I would be removing if I had one installed. Hopefully Hurricane upgrades these.Can't get Dave to call me back so IDK. Disappointing.
Turboflash
- Mar 18, 2019
- Southern MN
Actually, this last one has ALLOT of extra venting facing forward.These sleds your finding these on do they have any additional venting up front? I have two vents up front in addition to knee vents which may help keep temps down.
- 4 large holes in front lower bulkhead behind intercooler
- Both side panels have both Frogzskin and the Speedwerx vents
- panel right in front of fuse block has 4 large holes with Frogzskin
- rear of both side panels have large rectangular vents
- both side panels have multiple round Frogzskin openings where there's room.
IMO, whatever material these are made of cannot take the underhood heat. Need much better material such as what Twyztid posted just above.
I've called Dave and emailed him over a month ago. I sent him many pictures of the failures. Still waiting for him to call me. I bet he knows there's a problem but doesn't have a plan on how to deal with it.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I wonder if this is going to go the way of the stub shaft knockout kit. Very popular at first, but in the end it didn't work long-term as intended.Actually, this last one has ALLOT of extra venting facing forward.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Just checked mine and it looks fine. Weird
Turboflash
- Mar 18, 2019
- Southern MN
This one did too right up to last 500 mile trip. End of trip, he said boost was down.Just checked mine and it looks fine. Weird
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Ya I haven’t done an big mile trips this season so maybe that has something to do with itActually, this last one has ALLOT of extra venting facing forward.
Well it’s a good idea I hope these issues get resolved
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
If im not mistaken GAP makes these , maybe try contacting them
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Its probable there's a boost level threshold causing this part to expose its weakness/flaw in craftsmanship. Too bad it wasn't thoroughly tested prior to shipping.
Unfortunately, when the 2nd Gen version comes out, im going to need a $110. credit. And we all know that's not gonna happen.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
How's that? Isn't this tube between the airbox/filter and the turbo (no pressure)?Its probable there's a boost level threshold causing this part to expose its weakness/flaw in craftsmanship. Too bad it wasn't thoroughly tested prior to shipping.
Doc Harley
- Oct 17, 2016
- Here & there
Extended runs @ 20psi create more heat than say 16psi would.How's that? Isn't this tube between the airbox/filter and the turbo (no pressure)?
I know TF and his circle run 18psi+.
- 6K
