Hygear DRS
WinderFab
Woodbridge, ON
Canada
2020 Sidewinder Ltx GT
Just had my rear shocks revalved and added the DRS for the center shock on my 2013 120” nytro..
Woundering if anyone has some preload setting for hygear dual rate spring on center shock ? or a starting point for a 190lbs rider..
I recently installed one on my buddy's XTX. Hygear instructions indicated starting at 5mm, as the springs are specific to your weight.
5mm is correct and then adjust as needed after you have ridden for a while. I think I ended up somewhere around 7-10mm with the setup I have. It doesn't take much so a little at a time and then ride it and change it up or down from there. I actually ended up going back down to 7-10mm from somewhere around 15-17mm it was to stiff.
Pete
