garserio
- Nov 30, 2004
- Fairport, NY
- 2014 SR Viper
2001 AC Z370
2006 AC F120
For those running the Proactive suspension in the 07/08 RTX, 06/07 Nytro or 05 Vector (also applies to Phazer owners, too), you know about this skid's weaknesses, especially the center link that couples the center shock to the rear shock. After 4 seasons of fighting this suspension in my 05 Vector, I made my final attempt to improve it by adding Hygear's modifications. Here is what I bought:
1. Linkage Kit
2. Center shock rebuild, revalve, dual-rate spring kit (Twisted Springs) and add-on reservoir (reZe)
3. Rear damper (In my case the Ohlin) rebuild & revalve
4. Torsion Spring Spacers
Cost: $1,180 incl tax & shipping
Squawk List / Motivation, Results (Reasoning):
1. Severe bottoming, Mimimized by 80% (DR Spring & compression dampening progression)
2. Stutter bump smoothing, Couldn't feel them! 100% gone! (DR Center Spring)
3. Rear kickback (Beaver-tailing), Minimized by 90% (Rear damper valving)
4. Center shock fading, Minimized by 60% (Add on reservior for more oil volume = longer to heat up, more surface area to cool)
5. Center link failure, None noted nor expected since stress of shock coupling is eliminated. (Linkage Kit)
6. Center idler wheel warping, None noted nor expected since kit included beefier wheels with the 6205 bearing. This is a proven solution as noted from my and others past work with wheel improvements. However, the Hygear kit uses a smaller wheel, so the bearing will be spinning much faster which could affect longevity... time will tell.
Bottom Line:
I wish I made this move years ago! This is by far the most comprehensive improvement package available for this skid. It addressed every deficiency I felt the skid exhibited. Although the price may seem high, I feel it lived up to its promises and have spent at least as much over the past few years with "piece-wise" improvements that did not fully solved the problems. I revalved shocks, tried numerous springs, upgraded to Ohlins, beefed up components, and played with every adjustment on the skid logging over 4,000 miles on very rough and smooth trail conditions. Every combination I tried was optimized for one set of conditions. With Hygear's setup, I feel the skid performs extremely well in rough conditions without sacrificing smooth trail performance. This is due to the highly progressive nature of the valving and spring setups. I actually like my sled again!
I had a few small challenges with installation, but those were resolved by speaking with Hygear who spent ample time working with me. It turns out that the linkage kit was developed using a Nytro and it seems that the Vector is touch different with its center shock which necessitated a location change for the center shock mounting shaft. Also, the Vector's torsion springs are lighter and have a slightly smaller ID which necessitated smaller diameter torsion spring spacers. If you choose to install this kit on your 05 Vector like I did, PM me for advice...
In 100 miles of riding, I was able to dial in all the settings. I had way too much rear damper compression dampening in the beginning. The center shock was doing all the work and was bottoming too quickly. I noticed that the rear of the sled was not moving as readily, so I set my rear damper clicker to a softer setting and the problem disappeared instantly. With the addition of the torsion spring spacers, I found the spring to be more efficient with the "Soft" setting being more than adequate for me. This was a plus because I was able to get the desired ride height without having to preload the springs too much. I am running 50% transfer on the rods, full limiter strap length and just enough center spring preload to keep the assy taught at full extension. (If you preload the center spring too much, you will simply "consume" the amount of travel necessary to collapse the lighter spring thus wiping out the majority of your dual rate spring performance.)
So that's my report. I'll update as I log more miles, but right now, I highly recommend this kit to anyone who is distraught about their Proactive and willing to spend the time to dial it all in.
1. Linkage Kit
Bottom Line:
