hyvo?
Stock chain is hyvo and gears are Borg Warner.
OK so this poses a problem than,i have a borg 38 bottom,and stock yammie 21 top,i could run that combo,if I had a P/N for the correct hyvo and pitch chain. Now I have been running,stock yammie I guess hyvo chain,on stock 41 borg bottom,and cat 22 borg top,with 3600 miles on them,but do not know what it looks like in there now either.
22/41 takes a 86 chain, to go 21/38 You need a 84. You'l need a new chain or shorten the one you have.
TOP
20
21
22
24
Bottom
35
36
37
38
41
48
49
50
53
54
ok - but they r the same difference --- correct - u can use a hyvo chain or a borg warner chain with borg gears - - i do and it works fine. and those gear teeth numbers are great but need part numbers - i have a sheet for top gears but could use the 35, 36, 37, and 38 numbers if someone has then handy
There is a post on here concerning the diff between the HYVO and the silent chain/gear. Knapp posted some pics of the 2 side by side for one to see. The difference is shown and explained.
Do a search, it's some good info.
Copy and pasted from internet site so use caution. Also there is different top gears with holes pre drilled in them now. Always 15W top and 13W bottom. These are Arctic Cat gears.
Top Gear with oil holes
21T 1702-490
22T 1702-491
Four Stroke Top Gears: (no oil holes)
20T 15 WIDE 1702-423
21T 15 WIDE 1702-394
22T 15 WIDE 1702-395
24T 15 WIDE 1702-396
Bottom Gears:
35 tooth 13 wide 2602-831
36 tooth 13 wide 2602-833
37 tooth 13 wide 2602-834
38 tooth 13 wide 2602-836
41 tooth 13 wide 2602-745
48 tooth 13 wide 2602-790
49 tooth 13 wide 2602-758
50 tooth 13 wide 2602-746
53 tooth 13 wide 2602-746
54 tooth 13 wide 2602-746
Chains:
15 wide 84P 2602-838
15 wide 86P 2602-839
15 wide 90P 2602-840
15 wide 92P 2602-841
15 wide 98P 2602-945
Required Chain Chart:
gears chain
19/50 90 P
21/49 90 P
20/46 88 P
23/51 92 P
22/48 90 P
24/50 92 P
21/41 86 P
21/38 84 P
20/35 82 P
23/40 86 P
22/37 84 P
24/39 86 P
23/36 84 P
24/35 84 P
Thanks,yes I did know I needed a 84 pitch chain,just want to find a correct P/N so I can look to purchase it.
