beeze455
I am no expert rider and I am not riding wicked steep terrain, but I should still be able to put this thing on its side from time to time. Couple non-yammy buddies go on it and said the same. Plan on looking into those skin a-arms when they come out, but what cna I do now? Looking for some tips.
2011 XTX
Removed sway bar
tried and low settings on the front shocks
1.25 ripsaw track
roll over kit
pilot 6.9 skis
not that these matter
Roest skid plate
excel headers
geared and clutched
trail tank
2011 XTX
Removed sway bar
1.25 ripsaw track
roll over kit
pilot 6.9 skis
Roest skid plate
excel headers
geared and clutched
trail tank
natedawgedog
beeze455 said:I am no expert rider and I am not riding wicked steep terrain, but I should still be able to put this thing on its side from time to time. Couple non-yammy buddies go on it and said the same. Plan on looking into those skin a-arms when they come out, but what cna I do now? Looking for some tips.
2011 XTX
Removed sway bar
1.25 ripsaw track
roll over kit
pilot 6.9 skis
Roest skid plate
excel headers
geared and clutched
trail tank
I dont know if you've done this but the xtx has an ajustable ski stance, move the skis to the inside position helps a bit... another thing that seemed to help me with sidehilling and powder carving was installing the oft steering relocate and a bar riser.
Zakre
I suggust drinking heavily to gain a lot a mass to help throw her over, i dont have an issues, stand on the uphill side (duh) and lean back into the hill and off i go. That stock shitsaw track you have will not be helping.
Mountaintech
The wider ski stance really makes it harder.
also you should counter steer to start the motion....depending upon the snow depth, you might counter steer the whole time...
these sleds can side hill, just not as effortlessly as other sleds...
Alatalo
Considering your track choice, you are certainly an expert rider if you manage to even get close to a hill...beeze455 said:1.25 ripsaw track
Jokes aside, a wide ski stance and a track with no drive in powder do not help.
![](/styles/vip.gif)
Mtnviper
Vendor
If the skis have spacer collars, moving the skis in helps alot. Also on an XTX you can run a 2" to 3" bar riser with an OFT steering relocator. This will get the bars up higher and give you more leverage for counter steering/pulling it over.
When riding I like to put both feet on the up-hill side and with the 144" (shorter tracked sleds)I like to place my rear foot towards the rear of the tunnel. Then use a combination of throttle and weight on the back foot to keep the tail-end slightly "down hill" from the skis. This helps keep the front end from diving down hill so that you can hold the side hill longer. Also it is much easier to get a XTX to side-hill, going up hill across a slope then down hill. This is because your in the throttle more, which helps keep the front end up easier.
It takes a bit of practice to get it down, the best part is your having fun while practicing
Bill
![Div20 ;)! ;)!](/styles/default/xenforo/smilies/div20.gif)
Bill
Zipperno
Interesting topic.
Does "Carls Cut" help with sidehilling? Anyone done it?
I feel the Nytros balance point is like riding on a knifes edge.... Its hard to keep it in a controlled sidehill. The more snow/powder it gets easier.
![](/styles/TYLifeMember.gif)
yamahamm
- Oct 9, 2009
- Norway, Salangen, Troms
- Norway
- 2008 yamaha nytro mtx mcx 270
Zipperno said:Interesting topic.
this would help i think: http://www.ty4stroke.com/viewtopic.php?t=100802
Zipperno
yamahamm said:Zipperno said:Interesting topic.
Yes Im aware of this new front end. Hopefully it will help alot....
Im ordering the Skinz front end one as soon as it is available.
beeze455
I mentioned the skinz a-arms already and I know those should help. They are not available.
If weather agrees, I am going to change my ski stance, turn harder, grow a set and drink more.
Ruckus
Look where you want to go, drop your shoulder point your chin and push the flapper on the right side all the way forward. Its all about commitment. If you don't commit you won't be able to do it.
Super Sled
- Feb 25, 2009
- Summit X
Ruckus said:Look where you want to go, drop your shoulder point your chin and push the flapper on the right side all the way forward. Its all about commitment. If you don't commit you won't be able to do it.
X2.
![Flag :flag: :flag:](/styles/default/xenforo/smilies/flag.gif)
Nytroglycerin
x3Ruckus said:Look where you want to go, drop your shoulder point your chin and push the flapper on the right side all the way forward. Its all about commitment. If you don't commit you won't be able to do it.
im only 135lbs and its all bout commitment and countersteering for me, let her fall over and mash the fun flapper.
akvector
disconnect your sway bar!!!
I waited too long to do it on my mtx and now I can do down hill turns and go back up something i was never able to do before!!!
I do not notice a big difference on the trail with out it either but you do need good shocks
