I GOT APEX MTX 08 MODEL ANY NEWS?
Wendel
Postville, NL
i have this years model apex mtx ne one do anything to their 08 models i was thinkin of getting a turbo charger but i live in a small town and for the turbos u have to have special mixtures or race gas so i am just going to look for other stuff such as weight sets of mufflers (silencers) sparl plugs and other stuff to add horse power weight reduction maybe if anyone has any infp please do tell.
Wendel J
4 stroke 4 life[/u]
you could run the mcx turbo at 12psi on pump gas....lots out there and working awesome.....give you about 260hp..
You could probably just ride it stock and have a blast. On the RX1 mtn I put on the MBRP pipe, set the clutching for it to run right up to 11,200 rpm on hardpack so it would be as crisp as possible in powder. But the APEX is fuel injected and already is set up crisp. I'm not sure the after market pipe would be worth the investment. Make sure that you've got the right clutch rivets for your elevation so that you're not always into the rev limiter.
I like my sled best when I'm standing. Make sure your riser is the correct height for you, riding hunched over while standing decreases your mobility.
Set up your suspension to increase weight transfer and put on wide skis (i'm stock) if you're plowing through the powder. Left hand throttle can help when boondocking and sidehilling, but I use it far less on the Apex then I did on the RX1.
I rode both sleds bone stock for awhile and slowly changed things as I learned the sled's characteristics. The Apex stock is an awesome sled.
Now for the reality check....if you're a sledhead; turbos make these sleds easier to ride and way more fun. If you get an expert to do the install you should have a reliable setup and should not have to fiddle with it at all.
REXX
'07 Apex mtn. SE MCX rearmount turbo with low comp pistons
I'm running mcx rearmount at 16 psi with low comp pistons on pump fuel. (312 hp kit)
REXX
REXX
me too....just thought keep it toned down a bit till he is has control of the power at 260........lol
i was looking at the mcxprees on youtube on the apex man is he ever flyin up that hill i want power like that looks fun but i live in a small town where in the winter snowmobile is all there is so i dont want to go all out with the turbos but u guys said u can run it off pump gas well the smaller one i guess, the apex all stock is awesome standin up the risers are perfect lots of power i dont know how you would set up the mcx well i guess theres nothing to installing it but setting up the psi and everything is what im not sure about im going to go to school for small engine repair or mechanis in september so i gues shes stock until then, lol i was looking at those spark plugs man they add 2 to 3 hp on the apex thinkin about getting then rele expensive though 32 bux a peice i think it is put some weights in the clutch and if i ever won the jackpot on 649 or something man i would put a boondocker tunnel on it boss seat led tail lights. check this site out www.customsleds.ca its a place in ontario for u guys that live in nl or watever its an awesome place. has any one tried weight reduction? on the o8s?
educate me
can someone educate me on the psi methods so maybe i can purchase the mcx rele lovin the sound the power and the looks
one thing that i have noticed about my apex mtx so far is the suspension its rele soft and it is set at medium im not sure if its how i park it or not but when i left the back up just to see how the suspension is holding up its like 2 an a half inches or so until it brings up to its max height then u lift the whole back end of the machine up so is my shock gone maybe its just the place thats shes parked or what tomorrow i will stop it on a flat place and see whats shes like then but any ideas or anything on suspension extras upgrades or diff stuff please let me know . thanks to allllllllllllll sorry i never thought of this b4 or i would have put it all in one reply im newb to the forums so far but gettin hang of it
