yzf1999
- Dec 25, 2006
- Bloomington, Illinois
- 2015 Yamaha SR Viper LTX SE
Look at the skid under the sled.. toward the front you will see a strap hanging down with holes in it and secured at the bottom with two nuts and bolts. That is your limiter strap.. depending if you cinch it tighter or loser you raise or drop the front of the skid there by transfering the weight the sled either forward or back
Your exhaust header has a clamp attachment point ( 2 of them) wrap from there till just in front of the rear hole you've already closed off
zackn291
Well loosening it will move the weight to the back, which is what I want. I dont have to remove the ski or anything right?
yzf1999
- Dec 25, 2006
Yes loosen it all the way..the #*$&@ end of the sled will be allowed to squat all the way... remember that by doing this you will take weight off the skis and therefore kill your ski bight and cornering.. everything is a trade off
zackn291
yea I know. im not going to loosen it all the way, just a hole or two.
yzf1999
- Dec 25, 2006
Smart man..
zackn291
hmmm sarcastic much? i can always put it back to stock if i dont like it and find it too risky.
yzf1999
- Dec 25, 2006
I wasn't being sarcastic .. I was just saying you are wise by not loosening the limiter strap all the way
zackn291
right. will i gain anything if i get do an airbox mod and now exhaust mod?
yzf1999
- Dec 25, 2006
Maybe a little better throttle response... do air pods and your dirt bike exhaust and you'll notice it
yzf1999
- Dec 25, 2006
It's all about getting the most air in and out of the engine in the shortest amount of time
zackn291
could i get a set of bars and drill them so i could rivet the grips and have enough space for the light controls and grip controls?
yzf1999
- Dec 25, 2006
Yes.. measure the straight part of your stock bars that everything is connected to. Then find a motorcross bar that has the deminsions that you need. I have MSR bars on mine and everything ( even handguards) are on
yzf1999
- Dec 25, 2006
zackn291
do the msr bars have a cross bar or are they a flat type?
yzf1999
- Dec 25, 2006
Black aluminum with crossbar
