tundra
this night i would raise my handlebar, so i try it, but the handlebar dont move further than the stock position, i look closely and i find a small key in the u-turn of the handlebar, near the mounting bracket.
i have pull just a little bit, not that much, and cloak... the small key break.
there am suppose to be worried about that ? or is not that bad, what is the utility of that key.
but with my handle bar a little bit taller, this help a lot in powder riding.
i hope that is'nt a worse thing, that thing i have broken .
Someone know ?
Someone know ?
1xr
As long as the bar bolts are tight I can't see a problem, unelse it pulls the cables or wires too far when the bars are turned one way or the other. That small key is just a rivet and a spacer.
tundra
thanks ,
i have turn it over, but i keep a slack in the wire.
Mountaintech
Tundra, It is common practice to break (like you did) or remove rivet so that the bars can be positioned in a more upright position. We've been doing this for years out here in the West. RX FUN
