I need help with my Nytro 2009 XTX
No. But a butt load of plastic has to come off first. top a-arms are a long bolt with a welded nut, lower a-arms are two short bolts with nuts. Are you putting in oil lite bushings?
Yes, do you have some pics for me? Are you sure for welded nut? I tried to unscrew and the nuts seems to turn with the bolts.
You have to remove the top arms first, then remove or move the plastic the best you can so you can get a socket on the back nuts of the lower A-Arms. Kind of a pain compared to the 08 model but it is very do-able.
Yep, very tight. I set them in place and gently tap with a hammer to start. Then I placed a 2x4 piece of wood and on top and pound them into place watching carefully that they are going in straight. Some guys say they have them pressed in but I was able to do it as described.
I used a long threaded rod with some washers, squared up the bushings, and tightened the nut until the bushing was all the way in. Pretty easy to do. Ill look for a picture. I dont think i have any close ups though.
I like that idea, will try that next time..... ;)!
I hear putting the bushings in the freezer overnight helps too.
I did it!!! And with your tip it's very easy. If I can do this, anyone can ;o)
Thanks again guys and happy Christmas
This is the best way to install imo, goes in nice and straight and dont have to worry about breaking off the flanges.
