nicgagnon
To remove the arm front suspension, is it necessary to remove the airbox and the steering column?
thank you
thank you
Bahr05
- Dec 18, 2010
- Medford, WI
- '09 Nytro XTX
No. But a butt load of plastic has to come off first. top a-arms are a long bolt with a welded nut, lower a-arms are two short bolts with nuts. Are you putting in oil lite bushings?
nicgagnon
Yes, do you have some pics for me? Are you sure for welded nut? I tried to unscrew and the nuts seems to turn with the bolts.
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
nicgagnon said:Yes, do you have some pics for me? Are you sure for welded nut? I tried to unscrew and the nuts seems to turn with the bolts.
You have to remove the top arms first, then remove or move the plastic the best you can so you can get a socket on the back nuts of the lower A-Arms. Kind of a pain compared to the 08 model but it is very do-able.
markowinnipeg
Top are welded nuts. When you put it back together remember red loctite.
nicgagnon
Thanks guys!!!
nicgagnon
I heard that the new bushings were very tight. What is your procedure for setting up?
Apex2006
- Oct 26, 2009
- McHenry, IL
Yep, very tight. I set them in place and gently tap with a hammer to start. Then I placed a 2x4 piece of wood and on top and pound them into place watching carefully that they are going in straight. Some guys say they have them pressed in but I was able to do it as described.
Bahr05
- Dec 18, 2010
- Medford, WI
- '09 Nytro XTX
I used a long threaded rod with some washers, squared up the bushings, and tightened the nut until the bushing was all the way in. Pretty easy to do. Ill look for a picture. I dont think i have any close ups though.
Apex2006
- Oct 26, 2009
- McHenry, IL
I like that idea, will try that next time.....Bahr05 said:I used a long threaded rod with some washers, squared up the bushings, and tightened the nut until the bushing was all the way in. Pretty easy to do. Ill look for a picture. I dont think i have any close ups though.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
I hear putting the bushings in the freezer overnight helps too.
nicgagnon
I did it!!! And with your tip it's very easy. If I can do this, anyone can ;o)
Thanks again guys and happy Christmas
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
This is the best way to install imo, goes in nice and straight and dont have to worry about breaking off the flanges.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
nicgagnon
What's the cure for ths skis bolts in spindell?
