Oh Geeze. That's not saying much.And that is from the man that has one of the fastest NA Vipers on the planet.
Only if power is there to pull it. It's not. Keeping the clutches out of overdrive always helps speed and consistency though. I have a few more things to try for next year but I will say this. My 800cat all stock other than clutching beats my viper by about 3-5mph pretty consistantly. Before clutching Viper always beat it. The 800 Sits most of year because it's a cold,stinky oil and gas hog. On Viper do see 100mph on almost every ride somewhere just not always when I want it. Unless the 800's are running good or modded it will beat them. 600's are not a issue that I have seen. Just be realistic. It takes a lot of power to overcome the drag all that suspension causes.I would have thought the gearing would help top end a bit
2.08 to a 1.8 ratio should be higher speed at same rpm??
WillowAce
- Jan 21, 2017
- Northern Wisconsin
- 2016 Viper L-TX-DX - Sold
2019 Switchback XCR - Sold
2015 Viper L-TX-LE
2019 Renegade 850 - In the shed just in case
2020 Viper L-TX-SE
WillowAce
- Jan 21, 2017
2015 Viper L-TX-LE
2020 Viper L-TX-SE
In the twisty stuff I have yet to meet a Winder that walks away from me. Don't ask about what happens in the straights or lakes though.you still won't stay with them
Dstevenson
- Apr 8, 2018
- Norwood NY
- 16 viper 10 vector
Ok the project moves on . New trail can installed , home built air box mod done using D&D bullseye s . I have velocity stacks coming how do you securely attach them or is it just a friction fit ?
