turbine there is another post a couple down from this one ,apex keeps stalling.
I haven't tried to clean my tps yet or the iac but am going to.
anyways i can do the same as you , turn the addusting nob 1 - 1.5 turns and get little to know respons. this started a couple years ago and now my idle is all over the place and it will also stall on occasion. sometimes when i start it it will need some throttle to keep it from gurgalling down to 1000rpm and try and stall bla bla bla.
I think these are all connected to something and it starts wilh the idle running low then an adjustment then it works fine then as time passes more adjustment and then you get to the point where the guys are in that thread.
Maybe i'm just ranting
So no your not krazy or doing anything wrong nut you might be at the start of a dirty tps or a dirty iac.
Hopefully i will get time to clean these 2 and put me back like new.
Time time time
