scott32
- Jan 12, 2009
- huron county, ontario
- 07 Apex RTX se, 09 Nytro XTX
scott32 said:Densified air mass is making more hp/lb of boost. This kit may not feel much different because it is to my belief that the boost doesn't start to producing until later on in the rpm range. This allows for improved fuel economy at lower rpms and trail cruising speeds. I have no clue as to what is all included in this kit but $/hp is right there with any other kit but providing 30hp more /#. Hmmmm. If Yammi had an Apex replacement I wouldn't even care, but the stock viper is an un refined pooch.
kviper said:I would want to see those number's reproduced on a Dyno that I know is calibrated properly!??
kviper said:The Push kit's have never proven to be any more efficient than anything else on the Nytro's so what is changed to make 12.8 HP/LB on the Viper's?
The MCX kit on my Apex made made 11.8 HP/LB and some thought that was near unbelievable. Does this kit even have an intercooler? I think the Yamaha Push kit on the Nytro's didn't have a cooler?
My Apex is at about 215 at 5.5 LB, would love to line up with one of these 225 HP Viper's at 7 LB.
I edited my last post after reading the Push info! What boost are you running and what HP is claimed on yours? I was responding to the original post claiiming 225 at 7 LB.Yamadog said:kviper said:The Push kit's have never proven to be any more efficient than anything else on the Nytro's so what is changed to make 12.8 HP/LB on the Viper's?
I will be ready after tuesday, new limiter straps will be in by then hopefully. I really wanted to run the trail turbo only drags in 3 lakes WI today but found too much damage and no parts available
