Blown Up
Cyberdyne gauges. Make sure to get the boost only gauge. When setting up, you set if to read 0.0 to read solid otherwise it will flash under boost and is annoying. I have had really good luck with the gauges so far.
Thnaks blownup
its ordered and on its way I did get the boost only hate the silver bezel but was all I could find maybe the bezel off my dragon will fit it.
Blown up I was just at Pats last saturday and rode the push he has for sale. He told me that he installs afr's and boost gauges on all the units he builds?
loudelectronics
- Dec 1, 2007
- Souris, Manitoba
- presdwr.spaces.live.com
Why not the cyberdyne boost/vacuum guage?
Blown Up
Make sure when going through the set up you set it to 0.0. If you don't it will flash under boost and is very annoying. I had pats install gauges for me and am still using the afr gauge. I didn't like the mechanical boost gauge so ordered my own and swapped it out with the cyberdyne.
Yamadog said:Thnaks blownup
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
scott32 said:Are you installing Push turbos Allan? Do you have anymore details perhaps of what their kit entails?Srxspec said:Push is using a Power Commander for fuel control.
Sorry I do not have any other details, just what I have been told by a customer who has been researching all the different Viper turbo kits.
Nytros rule
- Jan 30, 2011
- Rider Nation
- 2014 Black Viper XTX
Compare MPI, MC EXPRESS and PUSH side by side.
Look at build quality, of the three
push would be my fifth choice.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Fifth out of Three.
Hmmmmm.
Assuming no
, Not a resounding recommendation.
Hmmmmm.
Assuming no
Blown Up
Everyone is welcome to their own opinions and can make their own decisions. Just like my opinion puts Push as my number one choice. That is what is great about having multiple options out there. Anyone that actually buys something as expensive as a turbo based on this site is crazy. It's a big investment and should explore all options and choose what you think is best and what fits best for you.
I am assuming you have ridden, worked on, and tuned all of the below kits to make such an assumption?
Nytros rule said:Compare MPI, MC EXPRESS and PUSH side by side.
scott32
- Jan 12, 2009
- huron county, ontario
- 07 Apex RTX se, 09 Nytro XTX
Blown up x2. His mathematical calculations are way off. With those numbers we'll be landing on the moon in less than 10 yrs.
TurboJamie
The best boost gauge i have used is a VEI high resolution gauge. It reads in .1 psi incriments.
MA03RX1ER
- Feb 12, 2007
- Georgetown, MA
- 2014 SR Viper XTX and 2003 RX1 w/MTN Conversion
Standard always inflates numbers. Let's see that again in SAE. Does look impressive.
