BV1
Nice, keep us posted.
-Steve
-Steve
SharkAttak
hey allen: any final results for the phaser yet?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Our main kit will be a primary spring and set of weights running $100 total. You will gain 2-3 sled lengths in low end and midrange acceleration with top end being the same as stock. In 700 feet the clutch kit was 3 mph faster than stock.
We will also offer Super Tip weights setup for the Phazer as well for those who are running nitrous or turbos. These will run $240.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Picture of the kit.
Phazer Clutch Kit
-Custom primary spring
-Weights
-$100
Increase in low end and midrange acceleration as well as quicker backshifting.
Phazer Clutch Kit
-Weights
-$100
monker
turn those weights around and take another picture.
SharkAttak
Srxspec said:Picture of the kit.
Phazer Clutch Kit
-Weights
-$100
hi allen:, so we shouldn't touch the secondary?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Joe, if we have to adjust the secondary at all it will only be with spring tension to slightly adjust for a heavier or lighter rider. At this time our testing has shown from 170 lbs to 220 lbs no secondary adjustments are needed.
SharkAttak
Srxspec said:![]()
thanks allen, can't wait to put the kit in
