sledneck22
So I apparently lost the bracket that the rear bogey wheels are mounted to on my last ride up north in the the U.P. I have been unable to find one thus far used and do not want to buy new as of yet. I am asking what happens if I don't get this fixed before first snow. Premature slide wear? Track problems? Anyone have a used bracket for a decent price? Thanks!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
bogey wheels...those were on my old elan....lol
you must mean idler wheels?....if they are on the inner idler wheels(between sliders) I highly recommend buying 2 bolt mounts from BRP....they are about 5 bucks at any doo dealer.
check out my thread on 2 bolt mounts
http://www.ty4stroke.com/viewtopic.php?t=78847
Dan
Dan
sledneck22
Yes I am talking about the inner idler wheels. So those one bolt mounts you speak of... you say they are only 5 bucks apiece? And any doo dealer has these? Part number? I checked your thread over and just didn't see anything that said cost or part numbers... Maybe I didn't look close enough.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
read the thread closer...its all there.
sledneck22
Alright ill have to do that tonight since I only have time to skim through because I am work...
Thanks for the help Dan!
sledneck22
BRP parts for 2 bolt mounts:
-503 190 389 (2 bolt mounts,need qty 4)
-207 088 544 (8mm x 85mm long bolts for INNER idlers only(need qty 2) outers you will use stock bolts)
-207 182 544 (8mm x 25mm short bolts for bottom of mounts,need at all locations,need qty 4)
-233 281 414 (8mm nylock nuts for all bolts,need qty 6 )
-503 183 100 (large washers for against wheels,needed at inners only,need qty2)
So I am assuming these are the parts I need to get... well at least pick out the parts I need for just the inner idlers? I don't understand the part numbers (because they are doos?) I would also assume taking these part numbers to a doo dealer they should be able to order this stuff up for me?
Thanks,
Kyle
Thanks,
Kyle
- 7K
- 15K
