Mountaintech
I have been building parts for FX Nytros for several years now and am expanding into the Phazer market. Looking for input in regards to skid plates for Phazers. For the Nytro I offer both a full length and short version. They are both constructed of 3/16" CNC laser cut aluminum, that is then machined, CNC bent, assembled, and then powdercoated. They are the finest out there. I want to be able to offer the same for the Phazer. Thoughts?
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
What's the weight?
I run a skid plate from a venture light, they are huge and give good floatations witch is needed due partly because of the low power... So whatever you make should be wide (if you ask me)
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Hmmm, I am sure your Nytro skid plates are really cool pieces. I have a Skinz float plate on my Phazer as I wanted the extra floatation along with the protection. It is hard to beat 1/4" HDPE for durability.
G.B.
G.B.
I agree. Same here. It was very noticeable in the deep stuff to have the extra floatation.
xt_gt
i've had the factory yami & now have a skinz. much better being wider.
if you do make one, make sure it has alot of surface area.
mountaintech, maybe make/offer some a-arms protectors to add to your business/products?
Mountaintech
Gone Blue said:Hmmm, I am sure your Nytro skid plates are really cool pieces. I have a Skinz float plate on my Phazer as I wanted the extra floatation along with the protection. It is hard to beat 1/4" HDPE for durability.
G.B.
Have you had icing problems with the float plate? The float plate stacks against the existing panels right? Has icing separated the plate from the chassis?
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Mountaintech said:Gone Blue said:Hmmm, I am sure your Nytro skid plates are really cool pieces. I have a Skinz float plate on my Phazer as I wanted the extra floatation along with the protection. It is hard to beat 1/4" HDPE for durability.
G.B.
I can see how that might happen. I have had ice between the float plate and bottom plastic belly pan. Nothing that has caused any issues so far. Thanks, G.B.
xt_gt
same here, ice just sits on top of skid plate. no ill effects yet.
i've tried drilling holes in the yami plate when i had it on, did nothing really.
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
SPG plate, A-arm protectors & Curve XS skis being pushed by the freeride- floats well
