otis
I am in the process of putting a 136" extension on my Mono RA rear suspension with 1.5" ripsaw. I am trying to decide if I should go with anti ratchet drivers or keep it the same.
What do you all think?
Otis
Otis
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
When you have the drive axle off anyway install the Ski-Doo 2.52 pitch extroverts they are durable and well manufactured. You will need a track with all windows open that is fully clipped.
Jack_Shaft
Anti-ratchet's are great for the low end torque that these sleds produce. The 'Doo ones are the best out there and considering that they're so inexpensive, you're getting a great bang for the buck.
I have anti-ratchet's and I would not go back to regular drivers.
Mongo 1
Whose kit are you using to stretch your mono? I would like to extend mine, but gave up because of geometry problems. Did you pick up a 136 mono skid instead?
otis
Skidoo extroverts
Does anyone have the part numbers for the ski-doo drivers? Do I need just 2 for the inside or all 4 like stock? How do I get the old ones off and the new ones on? Do I need to take them somewhere and get them pressed on?
Thanks for the advice.
Otis
PS I am running the trackusa rail extensions and hartman tunnel extension. I don't think the track will get too messed up with the extensions and if I run the track loose with the extroverts.
Otis
Jack_Shaft
BRP Extroverts are as follows:
8 tooth #504152552
9 tooth #504152503
10 tooth #504152502
these drivers are appx. $50 US each
I wish I would have installed these instead of the Kinetics I'm running now. The Kinetics are good, but these are better.
You need only two drivers and you will have to press them on/off. Have a shop do that for you, they'll take all the measurements and place them accordingly. They shouldn't charge you more than 1/2 hr labour for that.
8 tooth #504152552
9 tooth #504152503
10 tooth #504152502
JDMCRX
So these are anti rachet devices still?
otis
What is stock for an 03 RX-1 8,9 or 10 tooth drivers? What will happen if I use them on a track that is clipped only every 3rd window?
Otis
Otis
JDMCRX
If u use a antirachet device on a non fully clipped track ur gonna do some dmage to alot of things and its gonna vibrat like a bitch
black john
drivers
rx 1 mtn,s came with 8 tooth drvers. std rx 1,s came with 9 tooth and yes you must run a fully cliped track. as well as cut down the drivers.
JDMCRX
What do u mean john as cutting the drivers down. Are the ski-doo ones too long??? Anyone have pics of them?
craze1cars
JDMCRX said:If u use a antirachet device on a non fully clipped track ur gonna do some dmage to alot of things and its gonna vibrat like a bitch
I've run anti-ratchets in the past clipped every third on some race sleds, it works fine with no vibration or damage. You need to have all the windows OPEN of course, but you don't necessarily have to go full clip. I do imagine the track will probably last longer in a trail application if you clip it fully though.
otis
What is the consensus? Fully clipped or not with extrovert drivers?
Otis
Otis
JDMCRX
Oups my bad I mean to say all open windows lol. Sorry
Turbo Tim
otis said:What is the consensus? Fully clipped or not with extrovert drivers?
Otis
If you use hiperfaxes , fully clipped . If you use stock hyfaxes all windows have to be punched open , but only every 3rd clipped. Hyperfaxes will melt your track ,if not all clipped.
- 11K
