yamahacat69
guys im running around 25 pounds of boost on my rx1 with a home made intercooler and i have had float bowl preasure problems for years .a month ago put on my buddys cpr intercooler and huge improvement. i got to have one but i was reading few years back that the trail intercooler is not big enough for 25 pounds of boost. im woundering do anyone know were i can buy a good intercooler for what i am lookin for even a pic of one i would love to see. thanks
yamahacat69
anyone with anything
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
What kind of float bowl problems are you having ? Do you have seperate lines running to each set of carbs. You can't just run one pressure line and tee off of it to the carbs or it will never run right.
Ken....
Ken....
DEC
inter-cooler
Have inter-cooler, with carbs,regulator, cable , many spare jets, mis. parts.ready to bolt on! Will support over 500 hp. Went to fuel injection. Call Dennis 312 590 3220 630 595 7662 773 458 0295 0r pm me racer4522@att.net . Many other parts
yamahacat69
i had it the same way my buddy did on the cpr intercooler single line from the cooler then a tee then to the float bowls my understanding thats the way it supose to be.i had lots of different issues big sputter off of the line lean on top end kept goin up in jet size to fix my afR the lean problem but more i go up in jets the worst it would run like i said i had issues for about 5-6 years steady picking at it. i put on the cpr intercooler and in 10 min it worked like a dream i was shocked
yamahacat69
pm sent
