scooterwj
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Im sure any low temp sealant will work fine...
Turboflash
- Mar 18, 2019
- Southern MN
Yeah, that will work.
SPM
- Nov 18, 2018
- so. mn
- 2018 Sidewinder L-TX LE
That will work. Use Pematex "Right Stuff" and I know it won't fall in. Kinda pricey for a small job like that though. No matter what you use make sure it's very clean and dry.Just want to seal it up to prevent it from falling in!
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Why did it fall out?Just want to seal it up to prevent it from falling in!
Byam
I have use exactly this product inside.Just want to seal it up to prevent it from falling in!
Outside this
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Yes the ultra black works well..be sure to clean area inside incredibly well, if it's oily it won't adhere for any length of time. Build it up to get good contact on interior corner of case, as the issue some had was falling INWARD, can't fall outward.
Dan
Dan
scooterwj
Dan
View attachment 150532 View attachment 150533 View attachment 150534
What do you recommend cleaning it with?
Turboflash
- Mar 18, 2019
- Southern MN
Brake cleaner or anything that gets ALL the oil off the case.
Pstn head
Electrical contact cleaner, leaves no oil residue.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2017 Sidewinder LTX SE - TD Power Trail, CAI, 3" Super Quiet
2012 RS Vector
2006 Apex GT
- Middleville, MI
I used JB weld on the outside around the outside edge of the glass to the aluminum case. I also put some around the edge of the speed sensor because I have seen those come loose as well.
Turboflash
- Mar 18, 2019
- Southern MN
Brake cleaner leaves no residue.
This one is CRC Brakekleen available everywhere.
20 OZ AEROSOL BRAKLEEN BRAKE PARTS CLEANER Cleans and dries fast, leaves no residue; Degreases instantly; Works without disassembly; Contains no chlorinated solvents; Use where compliance calls for a chlorine-free product; Model Number: 05084
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Brake cleaner I use alot for a quick evaporation and nothing leftover. Take care not get it onto the rubber gasket/grommet in which the sight glass is set in to.
Dan
Dan
scooterwj
Dan
Opps I was not careful about not getting any brake cleaner on that grommet that the sign glass sets into... But did make sure it was dry before putting on the ultra black.... I also have clear adhesive sealant on the exterior rim of the sight glass... I hope that will be ok?
Turboflash
- Mar 18, 2019
- Southern MN
You'll be good.Opps I was not careful about not getting any brake cleaner on that grommet that the sign glass sets into... But did make sure it was dry before putting on the ultra black.... I also have clear adhesive sealant on the exterior rim of the sight glass... I hope that will be ok?
