Apex Enthusiast
Hi, battery seemed a little low when I started it. Yamaheater light flickers at idle. Sled bogs momentarily if I fully hit gas. Power issue? This is a vid. of it. Thanks!
Light will ficker when the idle is low and is the sled fully up to temp? does it have any mods?
Might need to pop in some new plugs.
Idle is low. This low idle produces lower than normal operating voltage and will cause the Yamaheater light to flicker.
Apex Enthusiast
Just headlights and Yamaheater. Sled had warmed up for about 10 min...Light will ficker when the idle is low and is the sled fully up to temp? does it have any mods?
Winderallday!
Fresh gas? Def try new plugs.
If running in warm shop, ambient temp sensor/ECU may be altering idle characteristics.
If you are running HIDs they will flicker on low idle on start up or if voltage is low. Make sure that battery has a full charge.
Apex Enthusiast
Going to do that!If you are running HIDs they will flicker on low idle on start up or if voltage is low. Make sure that battery has a full charge.
