yamaslob
I was reading I think in Snow Tech that if you have an 05 Vector you can switch the key to the on postion and hold the grip warmer down all the way for 8 seconds the gauge will come on along with head light. So you can read the gauges with out wasten gas.
Will this work on my Nytro, it has the same set up as a vector.
MadMax
I know it works with the thumb warmer..Never tried holding the grip warmer.. It's cool if you are out on the trail and one of your doo buddies break down you can use the head light without the motor running.. Not sure about the nytro.. You would think they would do it on all the 06s. MM
I have been using this on my RS Venture
Snakebit
Seems to work on all the RS series sleds. I like that feature.
yamaslob
MadMax said:I know it works with the thumb warmer..Never tried holding the grip warmer.. It's cool if you are out on the trail and one of your doo buddies break down you can use the head light without the motor running.. Not sure about the nytro.. You would think they would do it on all the 06s. MM
Na not ski doo buds i got a cat friend hes always breaken somethen.
HAHAHAH
kviper
You Need to hold the thumb warmer switch down and then turn the key on while still holding the switch for eight second's and then every thing will light. kviper
Yama-Crazy
WOW it works! That will only work on rs sleds?
