thetruck454
Something doesn't feel right with my sled after adding the clutch kit/header/intake/cobra track/ PC5.
At first I thought the clutch felt squishy, so Allen told me to add a washer to the heel. Now it doesn't feel as squishy,but when I nail it, it doesn't exacly feel like its pulling that fast. I thought I felt something slipping/catching when I get on it, but not sure. Also part throttle doesn't feel as strong/jumpy as before all the mods. I'm trying to run through what could be causing it.
I need to find a field so I can stare at RPM's when I play with the throttle. all I've been on is the trail and I don't dare stare at the tach for long. I did notice when I get on it hard rpms are right around 8900
Maybe the clutch isn't dialed in? Or maybe the track is too tight. I don't think its the PCV,header,intake...
yooper1
I did all of that and the track was way too tight. easy it off a bit and try it.
what do your rpms jump up to at takeoff?
thetruck454
I seam to remember seeing 9xxx right as I jump on it. When it felt like it was slipping I was going to fast to take my eyes off the trail to watch the tach.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Make sure you have the secondary spring installed correctly. Should be 6-1 setting and then when you install the spring also make sure you wind it clockwise to line up the holes on the helix with the studs in the secondary.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
It's too bad you did all those mods at the same time. It makes it difficult to pinpoint the cause.
Maybe you can remove/disconnect certain/all mods, run the sled and add/reconnect one mod at a time to determine where the fault lies in your setup.
thetruck454
I'll double check on the secondary when I go up and ride it this weekend. Its probably the last weekend of the season, so I'll take it home and check for any assembly errors
thetruck454
I haven't had the secondary apart but I got a chance to look at rpms. This past weekend some times it would haul, other times it would not. When it felt like a dog, the rpms wouldn't climb and the motor sounded like it was working/lugging. Could that be the secondary sticking?
