SSX600
- Feb 13, 2010
- Richland Center WI
- 2010 Nytro XTX, 1997 Mtn Max 600, 1998 SSX600, 1975 SM292F, 1987 Inviter
whats going on with the nytro motors? Was looking at buying one need to know.
Groomerdriver
powderpimp1 said:Well this sucks!!! Pics Added!
Click here for the Pix!
http://picasaweb.google.com/Taritas5/06YAMAHANYTRO
Those are NOT pretty pictures! What kind of oil did you use and how often did you change it?
I feel sorry for you dude!
bjowett
Number 2 rod is the magic one.... The sled I just picked up had the same thing happen.
powderpimp1
I only used yamalube, and I change it every summer.
What needs to happen for me to try and get Yamaha to replace it???
Groomerdriver
powderpimp1 said:I only used yamalube, and I change it every summer.
A VERY polite call to Yamaha customer service. PM me if you want to.
watersuper
That is ugly.
Keep us posted on this issue.
powderpimp1
They said that a few things could have caused it. Oil, chain tensior, thrown valve. Who knows, buy I'm deffinitly not paying $4.800 in parts to fix that motor!
buddah
- Apr 14, 2003
- Wetmore, MI
- '17 Sidewinder B-TX LE
Not a pretty picture at all.
Some was say I was stupid, but that is the reason a bought the 5-yr. YES when I got the sled. If nothing happens it'll be looked at as a waste of money but if this were to happen...............
13,000 mi. and counting.......
Groomerdriver
buddah2 said:Not a pretty picture at all.
Ditto on the YES....I got my money's worth out of it.
maxdlx
I'd bet yes wouldn't cover this motor failure. i have a few friends who had stock sleds loose a motor the same way with yes, and Yamaha said nope, not there problem. Maxdlx
powderpimp1
Well whatever, however, wherever it dosent matter. I need a motor!!! And some help finding one!
maxdlx
I have for sale a 1000 cc 4 stroke engine out of a 2006 yamaha vector. it was removed from a wrecked sled with 1200 miles. I am asking 2000 with ignition, carbs and starter. I purchased it for costom project and have since gone with a different engine. 612-219-3082
found this on snowest
buddah
- Apr 14, 2003
- Wetmore, MI
maxdlx said:I'd bet yes wouldn't cover this motor failure. i have a few friends who had stock sleds loose a motor the same way with yes, and Yamaha said nope, not there problem. Maxdlx
Hmmm, not to be argumentative (well, maybe just a little) but how the H*** could they basically disclaim responsibility for a stock motor going boom? Especially with maintenance records etc. to prove upkeep.
Mod motor, all bets are off. But totally stock?
maxdlx
Completely stock motor with the ever so often seen #3 rod cap broke. they said it was run low on oil, not or fault. Several calls to customer service with always the same answer, SORRY
just like the Nytro on here now, that the belly pan supports rubbed a hole in the filter and let it run out of oil, abusive ridding was there response, no help given. Its all in how bad your dealer wants to raise a stink
