Joe Gibbs oil - good stuff? Alternatives?
DelgatyXTX
Winnipeg, MB
I've even told there are certain oils you can run in Yammies that "free up" a few ponies. I'll be ordering some stuff from Ulmer soon and saw he has this oil. Is it good stuff? Are there any alternative performance oils out there as well? Going to run CR10EK plugs as well, is performance oil good to use with them?
Any help is greatly appreciated. Lots to learn with this sled! :)
tons of posts on here about oil.....and just as many opinions. Keep the oil at or near the recommended weights and you will be fine.
I thought there'd be, but I did a search for just "oil" and looked through 5 pages and found nothing. Normally I'm not a "start a thread instead of searching" guy but either I'm blind or just have bad luck with searches.
I'll just use the same weight as suggested. Thanks!
Delgaty...go on Ulmers site..he sells that brand of oil and he seems to really like it...might even be worth calling or sending him a PM about it..
I'm a diehard Amsoil fan, and so are all of my machines!!
That's where I first noticed it while I was surfing around for Nytro goodies. Probably will order some with my bushings, ball joints, etc.
I have had absolutely zero problems running the Joe Gibbs oil from Allen for last 2 seasons. If you are trying to get every hp out of your Nytro I would highly recommend it.
iqxpolaris said:
joe gibbs oil make 1 hp on dyno. 20$/liter
Good info to hear!
Thanks everyone!
