just installed pc5 with mapp!!
Good plan! I'm getting a tank built that fits under my tunnel bag.
awesome!!!! last year we came across a few lynx's nice animal to see !!! (just a pic from web) I was cruising when I seen them on 2 occasions !!
I just hope the two nytros that will do the ride have enough gas. Thinking about an auxiliary tank for my viper anyway.
I had this set up when I had my nitro, worked really good, strong and sturdy never had an issue and best of all you can bolt the mounts with "rivet nuts" and remove the mounts when not needed for a clean look. If your buddies need some direction as to where to mount them like measurements from running boards etc I'd be willing to help. They hold about 6ltrs each and I had one on each side.
The picture didn't come through, I'll try again
just finished all maintenance on my viper and decided to add the power commander 5 with the mapping from hurricane (for exhaust, air box mod and clutch kit ) Once installed she started right up with no issues
Hope to see some decent increases once the snow flies!!! I ran the exact set up last season minus the power commander and will give a honest opinion if it's worth it or not!
The sled seemed to be more responsive from before and after installing the pc5 and running on the stand but
I won't know truly until we get the white stuff!
Did the Powercommander 5 come with a map already install in it or did you have to in stall one?
