No it's not my first ride just started to lean out , I'm starting to think bad gas . gased up at a old service station and maybe it wasn't supreme gas
I would watch it and be light on it. You should be ok.
Try to increase the green setting to give it more fuel on the bottom.My worry is wen cold doesn't stay idle
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Possible air leak.
I think I developed one last trip out and a friend with a Turbo Doo had a similar issue.
michvent07attack
- Mar 11, 2013
- Grand Falls
- 2014 Yamaha viper xtx mcexpress 190HP turbo
ok will be looking into that thanks , how do u increase the green setting ??
Did you get the Gems controller? Make sure the all the vacuum and boost lines are zip tied and not leaking.
michvent07attack
- Mar 11, 2013
- Grand Falls
opps !!! didn't zip tie them , nope didn't get the gems controller , I installed the turbo and the koso x2 gauge that's it
michvent07attack
- Mar 11, 2013
- Grand Falls
I have a friend he took his sled to montreal on dyno and they adjusted everything as he wanted it , thinking of doing the same thing to be on the safe side don't know much about turbo's and adjusting better leave it to the pro's
no fuel controller??
michvent07attack
- Mar 11, 2013
- Grand Falls
might be because I store my sled in heated garage and forms condensation ?? i'll be looking into that too . thanks guys for the info very appreciated
michvent07attack
- Mar 11, 2013
- Grand Falls
well the turbo came with a box that communicate with the stock pcu
Then I would take it back to whoever you bought it from... If its not a gems box or a PCV I cant help.
michvent07attack
- Mar 11, 2013
- Grand Falls
it's a MC express 190 hp turbo
