Last years build (Thank you Ulmer)
sheetwright
Northwoods USA
2021 Yamaha SRX
Last year as some know I bought a 2010 Nytro RTX. I wanted to boost it for the trails of Wisconsin, and the U.P, and make it so it could handle like a Nytro should. I am glad to say thanks to Ulmer Racing/Allen that last year I had more miles on any sled I have ever owned in one year with just minor tuning here and there. All in all minus an Ultra Q exhaust that went bad on me, she ran great. Without a lot of time to test and tune with my schedule, this was th eonly way possible to build for me. It helped me a lot to be shopping for parts on here, Snowest, and Ebay to save a good chunk on this build also. Also Timing was everything. I even bought the blower before I owned the sled, just cause of the deal.
Sled 2010 RTX Orange and black. Drove all the way to Mason city Iowa to pick her up. Only 700 miles on sled at pickup
128 Star relocation kit (Allen installed)
Yamaha 4th wheel kit (Installed by me)
ExtrovertDrivers (By Ulmer)
1-1/4" quiet track picked (Allen installed)
43"+1" z-bros front end (Allen Installed)
Adjustable rox riser (Installed by me)
Rear Tour buddy gas tank (Allen Installed)
Mbrp header, copper doughnuts, and Ultra Q exhaust (By me)
Yamaha Aftermarket front and rear bumpers (By Me)
Head shim (Allen Installed)
Head studs (Allen Installed)
Cam timing (By Allen)
Mpi stg one s/c with custom blow off valve from ulmer (Allen Installed)
Large fuel pump, and fuel system from Allen (Installed by allen)
Van amberg rear heat exchanger (Installed By Allen)
Tunnel protectors (Already on the sled)
Ulmer clutching (Allen Installed)
Geared for trail (Allen Installed)
Machined clutch for more top end (By Allen)
C&A Pro skis (Installed by me)
Power commander LCD gauge panel for power commander (Supplied by Allen, Installed by me)
Power commander V (Allen Installed)
Digital Water temp gauge (Allen Installed)
Yamaha Extra wheel kit (By Me)
Hygear rear spacers (By Me)
Hygear dual rate springs and gyt dual clickers on the front (Installed By me)
Yamaha Racing tunnel supports (Installed by me)
Sled Start Hid lights (Installed by Me)
Muffin works rear skid support bars (Installed by Me)
Rear fat boy springs (By Me)
Yamaha Skid Plate (By me)
Rear OFT block off plate (by Me)
Graphic kit, and vent kit (Installed by me)
Dyno tested and run by Allen
Sled running at 12.5lbs of boost now using 93octane
This year I will have done to finish her up:
All shocks revalved front and back for my riding style, and weight. Need her to squat and dig, but not bottom out. Then adjust suspension a tad
Replacing blown out Ultra Q with Hindle slip on silencer
Power commander ignition module
Re-dyno her and fine tune it to see how much we can get out of it at 92 octane
Add a steering relocator
Change rear light to a larger LED light. (easier to see under the tank then)
Usual maintenance, oil change, lube, check bogies, and hyfax
more
Thank you for the great customer service Allen! ;)! :sled1: ;)!
Wow
Great sled
sorenson1610 said:
Very nice! What kind of mileage were you getting with the blower setup
I ride pretty hard, but not as Crazy as a Jo Blo, or Superman LOL and I am witihin 1-1.5 gallons of the other N/A Apex's in our group. I start looking 90 miles to a tank, and have taken it to 118 miles to a tank with about .5-.75 to spare
Thanks for the compliments guys. I love the way she came out, and it just feels even better after the last build went sour with two other builders on my 08 RTX.
I knew you would like a more trail oriented build and with Ulmer doing it you know its done right. 4 years later just another season for my SC apex haven't even thought of looking at the engine. Stretched mine out, made some gear changes, etc and Ulmer found 30 MORE track hp in the clutching. Dude is awesome and the sled is borderline insane (to me absolute insantity to others) and never skips a beat, just runs.
+10000000000000 for Allen!
Just switched to the trail tank for more of a stock look
