shaneway59
I was looking through boxes of parts I have kicking around the garage and I came across a msd 4350 launch master I had on my apex. Will this work on a nytro? If yes, what needs to be done with the 4th injector connectors?
Stigapex
Suspended
Will work, just forget the 4th connector. Connect 3 connectors and that works
apexgturbo
- Feb 9, 2012
- terrenceville
- 2008 Nytro,2009 Nytro mtx,2006 apex drag sled
It well work.just like stigapex said.
shaneway59
Thanks! I will give it a shot
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
Tees in to plug wire, not injector, correct?I was looking through boxes of parts I have kicking around the garage and I came across a msd 4350 launch master I had on my apex. Will this work on a nytro? If yes, what needs to be done with the 4th injector connectors?
shaneway59
Yes, correct. I'm use to working with pcv on my turbo Maverick all summer
- 16K
