Wiring MSD Launch Master
BADSLED
Syracuse, NY
2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
Can some provide input on best way to wire in MSD Launch Master to brake light on a Nytro. I also received a relay with the kit. Wiring schematic would be very helpful if available. ;)!
Msd
I'm installing the samething. I purchased the Msd along with the solenoid through hurricane performance. I sent Dave an email asking the samething. As soon as i get a response I'll let you know.
Dan give me a call or shoot me a text ill help you threw it I had it setup like that if you have the relay your good to go...I also hooked it to a button that I got from d&d which I have one still if you want that instead works great.
John, I will get a hold of you this week.. Thanks
On a bosch 40 amp relay the wire from brake switch put on terminal 86. on terminals 85 and 30 put those to ground. On terminal 87 that goes to msd launch master. What your doing is changing from a + input to a - output
here you go
