launch master on a rear mount turbo
tjc
New Hampshire
Can you get drag racing response with a rear mount if you use a msd launch master (on apex)?
Has anyone heard of downfalls with motor reliabilty with the launch master?
i run msd on an 06 apex 121 with 19T upgrade, leaving the line at 5 psi and straight to 20psi instantly............i wont even consider buying a front mount now.
no msd ignition required, takes about an hour to install.........i wired mine to the brake lever.
Freak you will need an MSD MC4 or better ignition to have launch control capabilities in your RX-1 as the MSD Launch Master 4350 does not work with a CDI ignition. I have this info from Dave Hurricane performance and Jim Onestop performance.
