apexg88
Havent found a thread where the different clutch kits are compared. I am interested in buying one but there are so many out there i cant decide they all claim to be the best???
If you have a clutch post the pros and cons.
If you've raced someone with a different clutch kit then you, post the results?
Low end, mid range, top end, overall?
Fix power sports? Pioneer performance? Ulmer? Boss? No Name? Which manufacturer has the best performing clutch kit?![Rockon :Rockon: :Rockon:](/styles/default/xenforo/smilies/rockon.gif)
renegademan17
- Mar 24, 2007
- Duluth, MN
- 2007 Attak, 97 700SX, 76 Ski Doo Olympic
I can say the Pioneer didn't turn any heads at our local drags last year! A little better than stock but had to tweak myself with primary spring and add weight on tip, better now. But for out of box performance was not impressed. Don't forget, all the clutch work is in vain if you can't get the power to the ground, i.e.. studs!!
![](/styles/TYLifeMember.gif)
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Ran my Fix & buddies Pioneer against STOCKER. NO difference...
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
My Hauck clutch kit actually slowed me down on top...
![](/styles/vip.gif)
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
apexg88 said:Havent found a thread where the different clutch kits are compared. I am interested in buying one but there are so many out there i cant decide they all claim to be the best???
Fix power sports? Pioneer performance? Ulmer? Boss? No Name? Which manufacturer has the best performing clutch kit?![]()
Personally I would try Ulmer or a Dalton setup.
enticer294
Clutch parts
Silver Secondery spring set at 100 degree twist 2-3 Mph Stronger Midrange cost 25 bucks
If you want to get to the front...call Allen
I really liked dragon fly's on my appex gt last year. I had 23/40 gears and some other mild mods. Fastest top end I got was 119mph gps. This set up rocked. I tried other sets befor. Scott really helped me out.
This year I have an 07 attack gt with yamacharger. I haven't completely got it set up yet. Still working on it.
ROCKRTX
j-mac said:I really liked dragon fly's on my appex gt last year. I had 23/40 gears and some other mild mods. Fastest top end I got was 119mph gps. This set up rocked. I tried other sets befor. Scott really helped me out.
Do you have you clutch cut?
Because 23/40 gearing will stop at 114-115 Mph with no clutch cut.
MUSKIE
Re: Clutch parts
...are you not making alot of heat and friction at the 100 degree setting which in the long run kills HP..??enticer294 said:Silver Secondery spring set at 100 degree twist 2-3 Mph Stronger Midrange cost 25 bucks
A silver at 100 is a lot less then a pink or white at stock settings.
skey01
Any input on Hartman kits????? :rules
polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Ted Jennety Clutching, jetting, air box mod.
Arctic Cat Z1 Turbo 128" Rear Suspension
128" Hacksaw 1" track.
Heated seat
Clutch kit
I don't know if Ted Jennetty makes a kit for a Apex or not but my clutch kit, air box mod and jetting has made my 05 RX1 a hot rod. Give him a call.
2001srx=fast
I got Hauck with the VP weights and i think it goes not to bad
apexg88
anyone know about the "trail terminator" clutch kit
www.2koolperformance.ca and click on "sledwerx" in the top left
