larrypolaris
'07 Attak. My LH hand warmer quit working this past weekend.
I need to fix it. Haven't checked it out yet. Is there a fuse I can check, or can i buy a hand warmer, or do I need to buy the whole
handle bar assembly. The hooked hanlde bars look like a bear to replace the grips.
motorman
hand warmer
you can buy yammi replacement grips.they were around $100 cdn apiece.or you could buy 2 rsi set ups for less than the price of 1 yammi,wire them up and have HOT grips.
i dont know whats wrong with yours,but you can test ohms at the connectors under the rubber sock.i think they are around 3 to 4 ohms .
you should also have a code on your display,and a flashing yellow light .cant remember the code.
